I have a Samsung Galaxy Blaze 4G, running Android 2.3.6, but I don't think this question is all that device-specific. If it is, someone will let me know.
I'm pretty new to Android.
This phone is rooted. I didn't install any custom ROM, however. I rooted it only to be able to use SetCPU and to be able to freeze/block some things, which I did successfully. This is where the problem starts.
I used a program called Gemini App Manager to block certain things from running. I had installed Launcher 7 and was using it for a couple of months. Today, I decided to return to TouchWiz for a while. I had blocked the TW files for some reason, but I used Gemini to unblock them. Or so I thought. I went through the motions of doing so, but didn't actually check to see if the unblocking worked. Apparently it didn't. Not knowing this, I uninstalled Launcher 7 from the phone and rebooted.
Now I can't get past the Samsung splash screen. It appears that TW wasn't unblocked, and with Launcher 7 gone, there's nowhere for it to go.
Yes, I'm an idiot. Let's get that out of the way first. The question is: Is there any way to fix this?
