Hello,
I have an Odys Loox, I boot up the unit with no problems I unlock it and then I get a black background and a message box... "Sorry! The application ADW.Launcher has stopped unexpectedly. Please try again" I force close... and this goes on and on and on.
So the little chap needs to be re-flashed.
So I downloaded the Odys Loox 1205 update. Inside it contains RKAndroid v1.29exe
The RKTool cannot find the device.......... I have read I need to install the driver manually... but I'm having problems with this bit... please can you help.
Thanks in advance
Thanks in advance
