So we're jumping back to VZW and getting Droid X's this Thursday.
I'm selling both my wife's and my iPhones - but having never owned a GSM phone (or iPhone) before I have a couple quick questions.
1) Can I still use iTunes to "restore" the iPhones and wipe everything off them once our numbers are ported over to VZW - or should I do the "restore" thing first? Should I uncheck all the various sync options in iTunes before doing so or will restore just nuke it all and not try to re-sync?
2) Should I remove the SIM card before or after I do the "restore"?
3) Do I have to return the SIM card to ATT - or just toss it out?
4) I'm assuming "if" I get my wife and I iPads later we'll be able to put all our apps we paid for on them from our iTunes accounts? Anyone know?
5) Is there anything else I should be doing with our iPhones before I sell them to make sure all personal data is off them?
I'd have asked over on the iPhone forums but I'm guessing I'd not get such a great reception with this post.
Thanks!
Thanks!
