Results 1 to 1 of 1
- 11-30-2012, 12:55 PM
Thread Author #1
Am I running into some kind of wakelock issue here?
I've been playing around with automation apps to try to conserve battery life, disabling data (W and M) when the screen is off, turning it on for a minute every 15 minutes or so to sync, then rinse, later repeat... then when the screen comes on, re-enable WiFi or Mobile (depending on my location)...End result is that I am toggling my data connection quite often, especially when the phone is asleep.
I've seem this on both AutomateIt and Llama... the above tasks works great, but every so often, things go south. When Mobile data turns on, it never actually connects up... Wifi will also start up but report "No networks in range" even though some are there. I've even seen it where Wifi connects, then drops a couple of seconds later and reports nothing in range. And the battery gets SLAUGHTERED.... even if I turn everything off, the batter graph looks like it's fallen off a cliff. The only way I can fix is a reboot.
One more event... when the Mobile data connection wouldnt establish, I tried to toggle the airplan mode, and it it never triggered..the airplane mode icon 'grayed' our (or dark green more like it) and I couldn't toggle it off anymore..only a reboot solved that. Figure this is all related.
I just installed BBS and am going to monitor for when this happens again, but does any of this seem familiar?
What kind of auto racing are you into?
By Jacques in forum AutosReplies: 24Last Post: 04-16-2013, 01:04 AM -
Need some help, run into a problem
By coogrrr94 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 10Last Post: 05-23-2011, 11:14 PM -
What kind of benchmark scores are you guys getting on your X running GB?
By kentusmc in forum Motorola Droid XReplies: 6Last Post: 04-13-2011, 05:50 PM -
Was there some kind of update?
By Evo4g in forum HTC EVO 4GReplies: 11Last Post: 02-22-2011, 08:46 PM -
I am thinking of rooting, but kind of scared to screw it up
By tmettler5 in forum Incredible Rooting, ROMs, and HacksReplies: 26Last Post: 08-21-2010, 01:02 AM
Reply
