factory data reset on a rooted android with some system applications removed
nishs13
Hello,
I rooted my phone to uninstall some bloatware system apps several months ago. Now, I need to perform a factory data reset just to remove the Google account associated with it. Is it safe to do so or will I lose any further system apps or worse, brick my phone? I have the apk's of the system apps that I removed, but for some reason I am not able to restore/install all of them. I used ES File Explorer back then to remove those apps. [My phone is Samsung GT-I5801 running Android 2.2]
Thanks in advance!
Avenger
50
If your phone functions now without them it should function fine when you factory reset. You can always download and re-flash the stock firmware if you are worried, depending on your model.
Mooncatt
Ambassador
Feb 23, 2011
10,758
321
83
If all you need to do is remove the Google account, I think there was a euro around posted on these forums not long ago so you don't have to factory reset. I don't remember the directions to post again, but try searching around here or on Google.
