Hello,
I rooted my phone to uninstall some bloatware system apps several months ago. Now, I need to perform a factory data reset just to remove the Google account associated with it. Is it safe to do so or will I lose any further system apps or worse, brick my phone? I have the apk's of the system apps that I removed, but for some reason I am not able to restore/install all of them. I used ES File Explorer back then to remove those apps. [My phone is Samsung GT-I5801 running Android 2.2]
Thanks in advance!
Thanks in advance!
