- 01-03-2013, 11:11 PM
Thread Author #1
- 01-03-2013, 11:13 PM
Thread Author #2
- 01-04-2013, 12:18 AM
Thread Author #3
Re: [EXPLANATION][Android 4.1][iOS] How Emoji works on Android and iOS
Note that on XDA there is a way to get a different emoji set, in this case Microsoft's Segoe UI Symbol.
You will notice some differences like somewhat bigger, clearer emoji characters as well as more emoji characters.
So far, there appears to be only two widely available emoji fonts which are non-Apple. This is AndroidEmoji.ttf and Segoe UI Symbol, recently updated by Microsoft to include emoji as below.
At this stage, there appears to be NO WAY to get the nice "picture" emoji like Apple because Apple apparently uses custom/proprietary extensions to the TTF file. You see these "picture" emoji in WhatsApp, etc. on Android because the app detects and replaces the unicode TTF characters with suitable images. It is apparently NOT in the TTF file itself, because TTF does not support colour or images at this stage.
Microsoft's emoji font is shown below for illustration purposes only because I believe this method to be illegally pirating a Windows font. - 01-05-2013, 08:21 AM #4
So my question is, my Nexus 4 can see emoji in other apps besides messaging (although in black and white). This was the case when I flashed 4.1 on my GS2, and its the case now on stock 4.2 for my N4. My question is, can GS3 owners or One X, S owners who have stock versions of 4.1 installed (Sense 4.1, Touchwiz 4.1) see emoji in other apps besides the messaging app? If so can you let me know how to get this to work? Because my brother came over from an iPhone after dumping android for about a year. He really didn't mind what phone he got just one thats not too big, takes great pictures, and would get 4.1 eventually on stock so he could send emoji again (doesn't want to root or anything). So now he has the One S because we're on the T-Mobile family plan. Loves the phone and pictures it takes, he still misses emoji though. When the One S gets 4.1 I just want to know if emoji will appear in other apps like Twitter and Instagram now. On my buddies GS3 that got the Tmobile 4.1 update about a month ago, I still couldn't see it from his phone so im wondering if this is only possible on stock Android. Thanks.
- 01-05-2013, 10:49 AM
Thread Author #5
Re: [SOLVED][Android 4.1][iOS] How Emoji works on Android and iOS
From my understanding, it appears anyone on 4.1, stock or not, CAN see emoji sent from someone else, in most apps. This is because 4.1 has this AndroidEmoji.ttf file.
On your friends T-Mobile GS3, try viewing the Wikipedia link above. Do you see emoji?
If you cannot, then it appears that particular ROM, stock Google, stock manufacturer, or custom, whatever it is, may not implement the "usual" 4.1 emoji.
WRITING emoji seems to depend more on stock Google Android having the emoji keyboard as described above. Non-stock-Google needs something like Multiling Keyboard.
So as far as I know, any manufacturer that implements Android 4.1 "properly" should show emoji. That is, you can SEE it. Like I said do check the Wikipedia page on various devices and let me know.
In summary, any 4.1 device like S3, One S, etc should SHOW emoji (like my One X), unless the manufacturer didn't do it "properly" for some reason. S3 and One S will need Multiling Keyboard to WRITE emoji because it is not stock Google Android.
I understand it is confusing, I believe I have figured out the theory behind it but need to try out different demo models at the shops in the next few weeks.
I admit we need to check out a variety of manufacturers but from a quick look non-Nexus, non-Google manufacturers do have emoji... People are starting to see it.
I am referring here to system-wide, as you mention. It is only Black & White because standard font files do not have images, it is custom stuff done by iOS and apps like GoSMS.
Thanks for the info and questions, we're starting to get to the bottom of this, seems like people really do like emoji...! 😃
Sent from my Nexus 7 using Android Central ForumsLast edited by sr2012; 01-05-2013 at 11:05 AM.
Thanked by 2: - 01-05-2013, 08:25 PM #6
Thank you that helps a little. Writing emoji is not a problem, there a various keyboards for this that i'm sure should work.
Another quick question, so assuming the manufacture didn't install 4.1 correctly, how could you correct this so you can see the emoji in 4.1 in apps like Twitter WITHOUT root? Like I said it is my friends GS3, haven't seen him today so haven't had a chance to check the wikipedia page you listed from his phone, but assuming he can't how could he? Or should I say...my brothers HTC One S is the main device I want to be able to see emoji from because thats the phone my brother has and he really misses that from his iPhone. Would it be in STOCK Sense 4.1? I know you said you're running a ROM on your One X but I don't know if you're running that based off of the Sense 4.1 and if it would even be in Stock Sense 4.1 - 01-06-2013, 07:40 AM
Thread Author #7
Yeah TrickDroid is based on Stock One X and Stock Sense for Jelly Bean so I assume HTC has implemented this stock.
I am going to try to flash Stock ROM by XDA user mike1986 and see what happens (I don't want to do that RUU stuff).
Sent from my HTC One X using Android Central ForumsThanked by: - 01-06-2013, 08:17 AM
Thread Author #8
OK confirmed for HTC One X Stock... Android 4.1.1, Sense 4+, Software Number 3.14.401.31, Kernel 3.1.10 etc. CAN see emoji as per my TrickDroid ROM.
So unless HTC decides to fiddle with Android 4.1, emoji should be there.
Regarding how to see emoji without Root, that, I honestly do not know how. There might be ways like installing AndroidEmoji.ttf in the userspace, not sure.Thanked by: - 01-08-2013, 11:13 PM #9
I am rooted and I had the Microsoft for emojis but then once i updated to jelly bean it switched over to the Android style. Kind of liked the Microsoft one but its whatever. Don't feel like changing it again
- 01-14-2013, 10:45 AM #10
- 01-16-2013, 07:17 AM
Thread Author #11
- 01-23-2013, 01:05 AM #12
okay i just rooted my 1st phone and downloaded the font “DroidSansFallback.ttf” so i could see emojis with me s3. How would i use the Microsoft font so i can see microsoft emojis ?! thanks!
Thanked by: - 01-24-2013, 09:43 AM
Thread Author #13
- 01-24-2013, 01:25 PM #14
- 01-26-2013, 02:29 AM #15
- 01-29-2013, 05:14 AM
Thread Author #16
- 01-31-2013, 02:19 AM #17
Hey guys. Came across this thread because I've been trying to get my S III (i9300) to show emoji in apps other than ChompSMS.
I was running an AOSP/CM hybrid rom (Liquid RC9) for a while before recently switching to a stock Samsung/TW-based rom (sotmax v14). When I was on Liquid, my phone had no problems displaying emoji (the default black-faced Android robots) in pretty much every app (Instagram included). Since wiping and flashing sotmax, no emoji show up whatsoever (blank spaces) except ChompSMS (but I'm guessing that's a native feature of Chomp).
I've pored through my /system/fonts and /system/etc folders, and everything seems to be in order for emoji to show correctly (I have both AndroidEmoji.ttf and DroidSansFallback.ttf in /fonts, and I also have fallback_fonts.xml in /etc), but I can't for the life of me make them appear!!
Note: I've looked into fallback_fonts.xml, and it has both AndroidEmoji.ttf and DroidSansFallback.ttf listed.
Note 2: I've since noticed that in the AOSP keyboard settings, inside add-on dictionaries, whenever I refresh and install "Emoji for English words", it appears to install, but when I exit and go back into the list, it's showing up as "Dictionary available"?
- 02-14-2013, 06:41 PM #18
Just thought I would let you know, Kii Keyboard is awesome to use for emoji. Its like SwiftKey but IMO is way better seeing as you can really customize it. Currently in beta but you can grab it off the store. You add on the handscent emojis and you get a full on emoji keyboard just like you would see if you ever used an iOS device.
- 02-17-2013, 10:42 AM #19
- 03-02-2013, 03:12 PM #20
Ios6 vs Windows
Is there a link to anywhere on the internet that shows almost all or all of the ios 6 emojis next to their cross platform windows equivalents? That would be super amazing. I want to know what each emoji looks like when i send an ios6 emoji to my friend who has a windows phone
- 03-08-2013, 06:55 AM #21
SO I now understand-ish why my JB s3 phone does not come with the AOSP keyboard (becasue the s3 is not a stock google Android...?). I guess the next logical question woud be, is there any way to manually download the AOSP keyboard, capable of adding on dictionaries (i.e. emoji for english words)???
I downloaded the Android Keyboard (LatinImeGooge_signed.apk) from here: but it does not have the "add-on dictionaries" option. I am grateful to now have autocorrect and a properly-spaced spacebar, but where can I find the real deal?
Screenshots: 1) before android keyboard download. 2) after DL 3) options provided within its settinLast edited by ebunny91; 03-09-2013 at 05:02 PM. Reason: Reread thread, found my answer. but i have followup
- 03-10-2013, 12:37 AM #22
Is there a way to see color emojis yet? I don't like the Android robots style lol
- 03-11-2013, 06:45 PM #23
- 03-12-2013, 01:09 PM #24
Too bad the Android emoji suck.
Whoever designed the Android smileys should be abused.
I think they got one of the programmers to do it in his spare time rather than actually hiring an artist. The icons lack wit, charm, and clarity. - 03-16-2013, 11:49 AM #25
Does Daily Show work on Android Tablets?
By charliegrs in forum Tablet ChatReplies: 4Last Post: 05-07-2011, 03:19 PM -
T-Mobile $10 Unlimited Data plan not working on Android ??
By ahmadka in forum General Help and How ToReplies: 2Last Post: 02-28-2011, 04:14 PM -
Java - does it work on Android?
By dstater in forum General Help and How ToReplies: 1Last Post: 02-02-2011, 12:21 PM -
Paid content does not work on Android?
By Epic4g_fiver in forum General News & DiscussionReplies: 2Last Post: 01-03-2011, 10:22 AM -
Voice Search does not work on Android 2.2
By Trace509 in forum Motorola Droid XReplies: 6Last Post: 11-16-2010, 03:36 PM
Reply
