I should start by explaining that I just recently made the switch to Android when I purchased a Galaxy S3 to replace my Palm Pre Plus. When I was still on webOS I used an app named Timepiece by ZeroPointSoftware as my every day bedside alarm clock. The thing that I liked the most about that app was that every alarm created had a toggle for recurring. If the toggle wasn't set then you could select a date as well as a time for the alarm to go off. The advantage to that was that you could create future alarms for something that is more the 6 days in the future. The benefit to that is to set an alarm to ensure that I wake up in time for a future event. The app also displayed the name of the next alarm that will occur along with the date and time it is set for on the main clock screen. This way when looking at the main clock screen you know what the next alarm is for not just when it is scheduled for. Does anyone know of an Alarm app for Android that can do the same things.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
