Hi everyone,
A while back I manually loaded the ICS leak onto my Droid RAZR maxx (my carrier is Verizon. it has worked great but I am ready to upgrade to jellybean. I don't recieve OS updates on the build that I have (4.0.3) and manual installs are failing. I figure if I can rollback to stock gingerbread or ICS 4.0.4 I then recieve the updates. In a perfect situation I would just be able to go straight to Jelly bean. Any help would be appreciated. My system version is 6.14.85.XT912.verizon.en.US
