Hi, I'm a newbie here so please bear with me.
I'm using the Galaxy Note (N7000) and whenever I use a function I now keep getting a pop-up box that asks me which App I want to use to carry out the action.
When I select one it then asks "Always" or "Just Once"... as I know which one I always use and press "Aways" up pops a second box which is titled Clear Defaults
under which it says... " clear default app settings by going to Settings > Application manager > All
but this option doesn't exist, has anyone else had this problem and if so how did you resolve it?
any help would be very gratefully received
thanks
thanks
