Just upgraded my Nexus 7 to the 16 GB model. After every thing is installed, I found "Sounds" didn't show
my custom sounds. A quick check showed the sounds it did show from the Facebook app were m4a not mp3.
Converting my custom sounds to m4a worked for about half.
What is going on? Only thing I can think of is the overhauled Google Play Music fundamentally altered how system sounds work. I can't get my newest ones to show. Anyone else find Android only allowing m4a for system sounds?
