So it all started a while ago when I turned off my phone. When I turned it back on, my Micro SD Card was suddenly reformatted. I don?t know why the heck that happened but everything on the SD Card was gone. Another thing that happened was I was unable to open any downloaded app. I was only able to open stock apps. Whenever I open a downloaded app, it would say ?Unfortunately, [APP] has stopped.? I thought a factory reset would fix all of this so I did just that.
I went into recovery mode and did Wipe data/Factory reset and Wipe cache partition. To my surprise, the ?Unfortunately, [APP] has stopped.? still occurred after downloading a single app. I thought it happened just for that app so I downloaded more apps but the error happened to all of them. I have done factory reset on my phone THREE TIMES but still no downloaded app seems to work although stock apps are fine. I have also tried clearing the data of the apps and even all the running apps on the phone but still the error appears. Please help me. My phone is almost like a brick to me now. Only the boring stock apps are working. I heard that replacing the Rom with a fresh new one can "possibly" fix it but I don?t exactly know how to do that or what a Rom is even.
Additional Info:
Version: 4.0.4
Phone: Myphone A888 Duo (Philippine local brand)
Had it for some months now. This is the first ever problem that I had with it.
Additional Info:
Version: 4.0.4
