Alright, let's keep this simple..
-Device - Galaxy S3 Mini (I8190L)
-No Recovery Mode
-Download Mode, Yes.
-Can connect to PC
-Adb not working?
-Can boot the phone and functions properly with little lag (most likely because i didn't factory reset it)
-previously, accidentally selected Nand Erase All, cut the process, and yeaah..
GOAL - Is there ANY way I can factory reset and wipe the data of the phone through Odin in Download Mode? It seems to be the only way I can factory reset it. Recovery mode doesn't work, factory resetting it the normal way (through the phone's settings) is not working, and yeah.
-No Recovery Mode
-Can connect to PC
-Adb not working?
