Kies is gone from my phone and wont connect to PC via USB Please Help!
Rick HKS
I just installed both kies and kies 3 to my pc and my phone was unable to connect to either one. my us has phone has been debugged my phone and i checked under connections for kies and it was no where to be found. i am running andorid 4.3 on my samsung galaxy s4. some one please help, connect my phone to my pc should not be this difficult.
thank you
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Have you gone to Tools in Kies and clicked on Reinstall drivers?
Are you using the original Samsung cable?
Are you connecting directly to the computer, not to a USB hub?
tivativa
