Just to make sure,
When installing a app (after confirm its permissions) - the persmissions like "contact", "calls", etc (all kind of permissions) - are disabled to the dev once I delete the app or he always have access to my info (at permissions) OR at the time I've download the app he have access to the permissions until I delete it and all the permissions are disable?
Usually this information/permissions are availabe to the dev automatically once I install the app or he need manualy to get into this informations?
If I force stop the app, will it still have access to my data (permissions) or only if its running?
Thanks!
Thanks!
