I had the same problem. Eventually I decided to have only 1 calendar app and one calendar widget app ('Agenda Widget'). This means that I have two widgets now visible: the one form the original calendar app, showing 2 out of 3 of my synced agenda's and the one from the widget app, showing the remaining synced agenda.
For me this was sufficient. I now have two separate widgets, each showing separate agenda's and I have a clear overview of both.
The only downside: I cannot put new items in the calendar that is visible in the widget app, since that is not a calendar app, but merely shows the items.
If you really need to have two seperate calendars, then I think the only solution will be to resort to the full versions of apps like bussiness calendar. Many Calendar apps have two versions, one for which you have to pay. usually it are the ones you have to pay for that have a feature where you can choose per widget separately which calendars it should show.
Hope this helps
