IN the last week my phone freezes within a few minutes of use. I mean no response at all to any taps, won't turn off even when pressing and holding the power button, nor will the power off menu appear. Then if I leave it on, within just a few minutes it overheats so badly it feels like I put it under a heat lamp. Tried everything I can think of with no results at all. This is the first time I have had any problems with this. I need the phone for work and some every elderly family members so I need it to work again. All is stock, with no tampering in any way at all.
What do you recommend, besides taking it in to a Verizon store?
Thanks much.
Thanks much.
