Resetting default apps
Hi,
I have a question about how I can reset the default app settings. For example, using Blinkfeed on my M8, when I tap on a link, the first time I was asked which browser should be used. How can I reset Blinkfeed, or any other app to ask me again which app to use? Is it always an app setting, or can I centrally control that behavior?
Hi,
