My tablet is rooted. As the heading says, I would like to do a true factory reset, not this "wiping data without wiping data/media" stuff. More like a unlocking the bootloader and watching your life flash before your eyes kind of wipe. How does one do that?
I did a factory reset from recovery, including wipe data. I even did it from regular settings where it tells you everything will be wiped and it booted into recovery and still left everything is there. Short of just going into my internal SD card folder and just deleting everything, is there another way to do it?
At this point, I'm just curious. I'm taking all this as a sign that I shouldn't do it.
Thx.
Sent from my "no longer 120° or battery guzzling" Sprint Galaxy Nexus, thanks to help from the AC forum
Thx.
