Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By B. Diddy
  • 1 Post By Rukbat
  • 1 Post By jayboiandroid
    jayboiandroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Should I get the Moto G on AT&T GoPhone or Samsung Galaxy III 4G LTE on Virgin Mobile?
    I'm going to get my pay from my job soon which will equal to around $300 tops. Should I get the Moto G 4G LTE for $219 on AT&T GoPhone prepaid or get the Samsung Galaxy S3 4G LTE on Virgin Mobile (my current carrier) for $191? I'm really worried about the coverage, but still factor in performance, storage, camera and the whole nine when you reply.
    Thank You!
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,049 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Should I get the Moto G on AT&T GoPhone or Samsung Galaxy III 4G LTE on Virgin Mobile?
    Which coverage are you worried about, AT&T or Virgin? I'm guessing AT&T will be superior. I don't have direct experience with either phone, but from what I've read in reviews and members' experience here on the forums, I'd suggest the Moto G. It gets high praise from most everyone, with excellent performance given its surprisingly low price. The new Moto G has the added advantage of 4G and an SD card slot. Perhaps the main advantage the S3 has is a removable battery.
    Do you know how much internal storage ROM each phone comes with? Make sure they have at least 8 GB, preferably 16 GB.
    jayboiandroid likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Moto G 4G LTE has 8 GB ROM (4-5 GB usable) and the Samsung Galaxy S3 4G LTE has 16 GB (11-12 GB usable) and when I said I was worried about coverage I was talking about both phones. I've been on Virgin Mobile for about 3 years now I can stay but is the S3 a better phone? Remember my main focus is gaming and watching HD videos.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    78,049 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    If you install fairly big games, then the S3 may be better for you, since it has more internal storage. Apps can only be installed on internal storage, so the Moto G might fill up fairly quickly.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats what im stuck on...I wish there was a phone that gets updated and has 16gb in this same price range because im mainly a gamer and YouTube viewer so this drives me nuts. I do have a 3DS however...
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,840 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    The first consideration is which carrier gives you the coverage you need. The best phone in the world, if that carrier doesn't cover the spot you're in when you need a phone call, is a useless piece of electronic waste.
    Check AT&T's coverage in the places you need coverage. (Don't just go to the block your office is on and see if it gets coverage. There's only one place in this entire town that has absolutely zero Sprint coverage - and that's inside my daughter's house. On the front step, on the rear deck, there's good coverage, but the only pace inside the house that has any coverage at all is one pane of one window in her bedroom. And only if the phone is held in the right position.) Radio signal propagation is an entire field, and learning the effect that causes a small space to be a hole in the coverage could take a few months of study.
    See if AT&T has coverage at your desk, in the rest room you use, etc. If not, you don't want any AT&T phone. Only when you know (if it turns out that way) that AT&T gives you the coverage you need will there be any reason to have to make a choice.
    Otherwise stay with Virgin and look for a better phone on their network.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is long overdue but I got the Samsung Galaxy S3 on Virgin Mobile a couple weeks ago and I love it. Thank you all for your answers and suggestions though
    B. Diddy likes this.
  1. LG G3 White AT&T for iPhone 5s or a S5 Active Red
    By ptb127 in forum Marketplace Archive
    Last Post: 07-21-2014, 01:51 AM
  2. Is the Sprint S5 a World Phone?
    By eyeoutthere in forum Samsung Galaxy S5
    Last Post: 07-19-2014, 11:57 PM
  3. Samsung Rugby Pro Question
    Last Post: 07-19-2014, 08:44 PM
  4. Samsung Galaxy S2 Stuck on Installing Updates
    By tanz89 in forum Samsung Galaxy S II
    Last Post: 07-19-2014, 05:04 PM
  5. Samsung galaxy legend, Verizon external sd card
    By Debbie Brown2 in forum Ask a Question
    Last Post: 07-19-2014, 04:28 PM
