Beep beep...
Jason Newstedt
Beep beep...beep beep...beep beep...
This is what I hear all night as I charge my Samsung S4 that was recently updated to "kitkat."
I plug the phone in to charge and the screen keeps coming on as if I just plugged it in, and making the beeping sound.
It won't stop. The problem started right after the kitkat update.
The screen flashes on every 15 seconds.
I have used the Kies software to make sure everything is up to date.
I have taken everything off of my phone and done a "master" (factory) reset.
Nothing worked to get it charge without sounding like a stoned robot.
Make it stop. Someone is going to die if it continues.
ShaggyKids
2,714
37
48
Is it possible an app is beeping? Maybe you need a new battery? Try plugging it into a different charger and see if it does the same thing?
devboilol
