LG G2 Keeps vibrating for no reason
Sushiiii
12
My phone vibrates like every 5 minutes and idk why. When it vibrates, there isnt a notification at the top so I dont know which app is making the sounds (if it's even caused by an app). I tried messing around with the settings and googling the answer, but couldnt find one. Anyone else have this problem?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,673
4,823
113
I was under the impression that you could go to the App Drawer and start opening apps--Safe Mode just prevents them from starting up initially. To be honest, I've never tried it myself (although I should, so that at least I know how it works).
JT1981
