Most people aren't aware of the stock battery icon that comes with their phone. You can find it by pressing the plus/add button then widgets > more HTC widgets. You can place the icon on your home-screen. The battery icon shows the percent of the battery. In addition to that...if you tap the battery icon a pop-up screen will give you more information about the battery.(i.e. health, larger batt percent, and batt type...etc.)
Ps. If your home page is full of apps - you can remove an app by sliding it off the screen.
(Check out the screen-shot below.)
