My car Bluetooth has lost half my contacts,and turned around the way they are displayed. How can I fix this?
A
AC Question
my car bluetooth has lost half my contacts,and turned around the way they are displayed.
The phone contacts are fine but will not download to the car, it seems to be since installing lollipop5.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,605
4,754
113
Re: my car bluetooth has lost half my contacts,and turned around the way they are displayed.
Welcome to Android Central! Which car? With my Nexus 5 and a 2008 BMW, I had to go to the Contacts app, tap Menu>Contacts to Display, and select Customize (instead of All Contacts), then select pretty much all contact groups. That seemed to work for me.
Non
