Foldermount & gl to sd won't work after root
I'm having some problems as I need to move some obb files from my SD to my internal memory. I've been told to use foldermount but after successful install it does not load and just says there was a problem. I tried to use gl to sd as an alternative but even though I have given it permission with supersu it says it cannot find my micro SD card. I have checked that my root is working with root checker, tried uninstalling and reinstalling, tried restarting my device but nothing I can think of helps.
I have a Acer E380, android version 4.2.2, kernal version 3.4.5.
Thanks in advance for any help!
