How do I reinstall Android?
A
AC Question
how to reinstall android
Hello I have a problem on my dad's Huawei Ascend Y300. It keeps closing Apps to a point when it is just restarting it self and then it locks it self on the Huawei screen after the reboot. hope I can get a tip to maby reinstall android.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: how to reinstall android
Rather than re-install the OS, try a factory reset. If possible...backup and sync your data as the reset will erase everything. Let us know how that works.
tress
