A
AC Question
Weather Widget on Home Screen
The weather widget on my Home Screen just doesn't work on my Note 4. I replaced the native weather widget (Accuweather, I think) with GoWeather, thinking that would solve the problem - but it doesn't. Both the time and temp/weather freeze at the time I turned on phone - I can have a time/temp that is several days old if I don't powercycle the phone. Does anyone have an idea what's going on with it?
