Re: whycant I setup my android for wifi?WWW
Welcome to Android Central! We need a lot more info than that. Which phone? Do you have a home wi-fi network set up already? Are you sure it's set up correctly--that is, can you connect to the web using other devices at home? Are you trying to connect at home, or somewhere else, like at work or at a cafe?
