Increasing the size of SD card
Hello, I have a replacement SD card for my P6000 elephone lollipop 5.0. the existing 32gb has some apps on there along with other files. The new 64gb is blank. Can I simple:
Copy the files from 32gb to 64gb?
Or should I back them up and insert the new card, which will then mean I have to install the apps from the play store again?
Seems a straight forward task but can't find much information on it.
