Can't connect to certain websites on my home wifi.
Hi. I'm having a very annoying issue where my phone refuses to connect to certain websites when connected to my home wifi. Her is the full story and details :
My router is a Netgear wnr3500Lv2. I had some home network issues and couldn't remember my router credentials (i know i know...) so I factory reset the router and set it up again. I set the SSID, password and general settings to be the same as before so that my devices wouldn't have to be reconfigured.
My phone is a HTC One M8 with android 5.0.1. I had to restart it because the keyboard wasn't showing up (happens sometimes). Now, if I try to access some websites, I get ERR_NAME_NOT_RESOLVED in the chrome browser (its the same in the default browser too). It works fine for other sites though.
exemple of working sites : google search engine, youtube, facebook, gamespot, polygon (partially), kickstarter loads but the layout is all fudged up, radio-canada.ca, ign,...
exemple of sites "not resolved" : reddit, all gawker sites, gamefaqs, star citizen's website, ...
I can access those sites without problems on my desktop (wired). I can also access them with my laptop (wireless) or my console. Only my phone refuses to do it. Hell, it can't even ping them. (I used PingTools). I thought it might be because of a security certificate my workplace had me install, being all confused or something, so I deleted all security certificates in the phone's security settings. Din't change anything.
It seemed to be a DNS problem so I set the DNS to 8.8.8.8 or 8.8.4.4 (google) in my router. Didn't change anything.
I tried forgetting and setting up my wireless network again in my phone. Didn't change anything.
Resetting the phone doesn't do anything.
The router resets connections every time I change the settings so there has been many resets there.
I know I could do a factory reset of my phone, but I would really like not to go there yet.
Just to re-iterate, everything was working perfectly fine until I reinitialized my router.
Any one got any idea? I can give you any network configuration information you need if required.
