Was casting my screen to a Chromecast device then switched WiFi networks and the (hardware) keyboard stopped functioning. Stuck in softkey mode only even after numerous resets (using reset button) and numerous system reboots. DO NOT SUGGEST A FACTORY RESET! I will hate you forever if you do. I have too many files to risk that...
