What device and Keyboard are you using? Typically, if you don't have a comma and semicolon keys on the number pad, it's usually replaced with a "Pause" key instead of a comma, and a "Wait" key instead of a semicolon.
If you don't see those, perhaps try changing to a different keyboard?
