I was thinking about how much stuff i can put on a 16gb micro sd card and i figured i could put most of my music, some movies, and a ton of apps on it but i was wondering will this would slow my phone down or kill my battery life?
@Cyber, I upgraded the SD card in my droid to 32G a while ago and ever since then, the phone has been almost un-usably slow at times. If this could be due to a corrupt file, is there a simple way to test this, and identify the problem file?You can fill up the media card as much as you want and it won't affect performance, UNLESS you have a corrupt file or something on there. Then it can slow things way down when accessing the memory card. Also certain apps recommend you keep them on internal memory for better performance but they will usually warn you before you move them... example.. Pandora Radio needs to be on the phones memory for their widget to work or Dolphin Browser recommends keeping the app on the phones memory. Other then that.... I wouldn't worry... fill the card up as much as you want.
One other place it will be obvious for most people is in the gallery/photo app. Once everything is loaded up, for the most part, I don't see a performance hit.
Not battery life. Performance can be affected if you use apps stored on your SD card or access large amounts of data on the SD card. Even with a class 10 SD card the SD card is significantly slower than the internal memory. Also, keep in mind that your SD card can only be read/written as fast as the device supports. It's really difficult to tell you how much of a performance hit to expect but it's not like filling up your PC's hard drive.I was thinking about how much stuff i can put on a 16gb micro sd card and i figured i could put most of my music, some movies, and a ton of apps on it but i was wondering will this would slow my phone down or kill my battery life?
