With the possible exception of a device that I didn't know had GPS until long after I broke the screen (I don't mean I just cracked it, it actually stopped responding when I touched it), every GPS enabled device I've ever owned has seemingly has GPS problems. That's three tablets and a phone. They worked fine for a while, but then they started not working right. They would say, "GPS signal lost" and then not work for anywhere from a minute to an hour. That's understandable for my phone since it only cost $60 (one of the cheapest no-contact Android phones you can get from AT&T and actually pretty good for the price), but the tablets all cost over $100 (except one was given to my dad by his employer and my dad gave it to me, and I bought one refurbished for less than half the normal price, but they would've cost over $100 if I'd gotten them new). My newest tablet, the Insignia Flex 10.1, was the worst. I ordered it last week and it arrived on Saturday, and I had problems with the GPS the first time I used it and every time until I decided to try something different. I downloaded GPS Test and everything looked normal, so I started thinking about other possible explanations for the problem. I decided to try a different app. That didn't work, but the one I was using was owned by Google, so I decided to try HERE Maps instead. Now it works just fine. My theory is that there's something wrong with Google Maps. That explains how every GPS enabled device I've ever owned can have the same exact problem. Has anybody else had this problem and found the same solution? Here's a list of my GPS enabled devices, in case that's important:
Samsung Galaxy Tab 4
ZTE Maven
Dell Venue 7
Insignia Flex 10.1
ZTE Maven
Dell Venue 7
Insignia Flex 10.1
