Hey all,
I'm hoping I can get some feedback on this. I'm a VERY longtime Windows Mobile/Phone/Mobile user, since back in the Mobile 5.0 days. I'm currently using a 1520.3 running Windows 10.
The phone is still a great piece of hardware, and I love the OS, but the app situation is killing me. There are apps that used to work on 8.1 that no longer work on 10, and I've been waiting months for updates that may never come. In addition, there's the seeming dozens of apps I'd love to use but don't have access to.
That said, I'm moving to Android soon (iphones are too expensive and too breakable, IMO, despite the fact that most of my friends use them). I'm looking at two phones and would love some feedback, especially from folks who have made the switch from Windows to Android.
1. Nexus 6P
Pros - Great build, large screen, stock OS with little to no bloatware, i like the rear placement of the fingerprint reader, 4k screen, easy OS upgrades
Cons - previous gen processor, no expandable memory, no wireless charging, a little pricey, no OIS
2. OnePlus 3 (Pros/Cons based on rumors)
Pros - Low Cost for the specs, high ram, current gen processor, low bloat, long battery life, MIGHT have expandable memory (I suspect it will have something similar to the X with the choice of either 2 sims or 1 sim and microSD)
Cons - 5.5 inch screen is about as small as I'll go (some rumors state a 5 inch screen), uncertain how well oneplus will update OS, camera on OP2 seemed lackluster so not sure how this one will stack up
I'm probably looking at another month before I make a purchase, and if I do end up choosing the Nexus I'll probably wait until the price goes down by $50 again.
Thanks in advance for your opinions and advice!
1. Nexus 6P
