I love the specs on some of the new HTC phones that are supposed to come out soon, but I don't like Sense. Does anyone know if, besides rooting, there is any way to get rid of it?
Well, you can always change the default home to something besides Sense. I have mine set to the normal Android home - three home screens, the standard app drawer. It doesn't eliminate Sense, but you never see it.
Press MENU button.
Press Settings.
Press Applications.
Press Manage Applications.
Wait for the OS to compute application usage.
Scroll down the list until you see HTC Sense and select it to go to the Application Info page.
Press the Clear Defaults button.
Press the HOME button. You will be prompted to select which app to compete the action with. Select Home and chose to make this the default action.
