I've done several factory resets. Uninstalled almost all bloat ware. Cleared all my cache on all apps.
Found link here that recommended, "to go Google Play, search for Webview and you'll see the update.....uninstall it". When I go to Webview in Google Play it says "Your device isn't compatible with this verison" (Android System Webview).
I like this phone and haven't even had it 1.5 years yet. I would like to keep it a little longer as I like to try to get at least two years out of my phone before upgrading.
Perhaps I need do download a different version of Webview what IS compatible with my device?
I don't think this phone dated to the point that it should be having so many problems, is it?
Thank you in advance for any help and advice.
