After using the standard "template" for setting up hotmail/live email accounts with the native client in my Fascinate phone (stock/debloated/SuperClean/Community Roms), I found that I could not get the client set up. I worked with Tier 3 tech support at Verizon, escalated levels of TS at Samsung, walked into Verizon stores and offered them cash money if they could configure my hotmail/live email account on my phone.... with nothing but failures. hotmail accounts would work, but not my live account.
"Self", I tell myself, "contact Microsoft and see if they can help". I used this link: https://support.live.com/eform.aspx?productKey=wlmobile&ct=eformts
After telling MS that I have already used the following settings, and failed, they stated that they would look into my issue and that I should hear back from them shortly.
I understand that you are unable to access emails on your mobile;
I apologize for the inconvenience,
I will be glad to assist you, I would like to inform you that I have made some changes on your account, please re-configure POP3 settings on your mobile,
Note: Kindly check your password you are entering, and should not be too long, because most of the mobile phone will not accept the password if it is more than 08 characters long, (Kindly reset the password if it is required)
Kindly follow the steps mention below and let us know the outcome.
1. on the Servers Tab,
2. Change the Incoming mail (POP3) and Outgoing mail (SMTP)
3. Incoming mail FROM pop3.email.msn.com TO pop3.live.com
4. Outgoing mail FROM smtp.email.msn.com TO smtp.live.com
5. Uncheck the "Log on using Secure Password Authentication" box
6. on the Advanced Tab,
7. Change the port number for Incoming Mail (POP3) from 110 to 995
8. Change the port number for Outgoing Mail (POP3) from 25 to 587
9. Check both the boxes that indicates "This server requires a secure connection (SSL)"
I hope this information provided will help you. For any other questions, please write back to us and we would be happy to assist you.
Thank you for contacting Windows Live for Mobile Technical Support.
Have a nice day!
Sincerely,
Sam
Windows Live Mobile Technical Support
So... I took 2 things away from this email.
1 - the original pop settings for my live account didn't seem to be the "normal" that everyone else is using (posted above), but they are now.
2 - passwords cannot be longer than 8 characters. It was originally 19. I find that this was not the likely culpruit because I had another live account with 6 characters that didn't work either.
Also, now my (pop) email works through my Bing toolbar on my PC where it didn't work before.
I changed the pw to under 16, but over 8, and IT WORKED!!! For the first time in 5 months, my email is configurable through the native client in Android on the Fascinate.
Here's what I did to configure the pop account, which is slightly different than laid out above. Note that my steps are based on no other accounts being set up with the email client.
Using the Email application built into the phone
Tap on the Hotmail icon
Under "Select Service" choose live.com
Under "Email Address" enter username@live.com
Under "Password" enter your password
Tap on Next
And I got the message: "Your account is set up, and email is on its way!"
I gave my email account a name and entered my name under that, and then tapped Done.
No need for manual setup. No need for anything. It just worked. And then my emails started showing up in the client.
There it is.
So, what should you take away from this? Some pop settings happen to be pop3.email.msn.com and smtp could be smtp.email.msn.com, both of these instead of what's published at hotmail and what Verizon tells their customers.
As much as I hated to contact Microsoft myself, I'm glad I did. It grinds me to no end that someone from Verizon couldn't do this and get an answer as to what to have their customers do to get the issue resolved instead of me finally getting so mad that I had to do it myself. Though it only took me two days from start to finish, how many other people can get something from this?
If changing your password to fewer characters doesn't fix the issue, or using the other pop and smtp settings shown above, I suggest using the link I provided and let MS know about your problem, explain the settings that you've already used, and maybe they'll do the same thing for you that they did for me.
Until the next time we meet... Peace, Love and Chicken Grease@!!
login/username - username@live.com
password - my email password
POP3 server: pop3.live.com
Port: 995
Security Type: SSL
Delete Mail from Server: Never
Because I cannot get past the incoming server, I am unable to configure the outgoing server.
This was their reply:password - my email password
Port: 995
Security Type: SSL
Thank you for writing to Windows Live for Mobile Technical Support. My name is Sam.
Have a nice day!
Sincerely,
Sam
Tap on Next
There it is.
