Lanhoj
Try LightFlow--> https://forums.androidcentral.com/e...geconsulting.android.lightflow&token=rr4nRmBY#1: Saw somewhere that the phone could (does) behave like a Blackberry, where a light appears indicating something to unlock the phone is there to check.
Try DS Battery Saver--> https://forums.androidcentral.com/e...m.rootuninstaller.batrsaverpro&token=-cTZvMC5#2 - I'm tight on money and have restrictive data on mobile provider. Do you know of an app that can "schedule" a shutdown of MOBILE data - say, Mon - Fri - 8 - 5?
Yup. Also, if you change your APN Type to only "mms" instead of "default,supl,dun,mms" while you're on 3G your phone won't be able to use any Data whatsoever except MMS which comes in handy for those on a tight budget. So you'll only be able to use Data when on Wi-Fi#3 - When I am in secure wi-fi (or unsecure in town) network, will the phone default and not use mobile data?
Set it to higher in some 3rd party SMS Apps#4 - When I receive an MMS text message (with a picture no greater than 1MB) from an iPhone it's displayed as a "slide show"....is there some kind of workaround?
Save your own # to your Contacts or set it manually in some 3rd party SMS Apps#5 - How do I load a picture of myself on my Android messaging app?
