N Nigel Huang Member Jul 29, 2014 21 0 0 Visit site Aug 4, 2014 #1 When I make calls and recieve calls, no sound comes from the earpiece at the top, the volume level is maxed out and nothing. Then when I go and press the speaker it works. The phone is only 1 week old... the only thing installed is battery doctor
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,602 4,748 113 Visit site Aug 5, 2014 #2 Sounds like a hardware defect. Does the problem persist after a reboot? How about a cache partition wipe? Keep in mind that the latter can take up to 10 minutes, but you won't lose any personal data: http://forums.androidcentral.com/nexus-5-rooting-roms-hacks/352008-guide-nexus-5-recovery.html If the problem continues, I'd contact the place you bought the phone and ask about a replacement.
U Umer Dawood Chishti New member Aug 7, 2014 1 0 0 Visit site Aug 7, 2014 #3 Same issue, tried everything possible from downgrading the OS and radio firmware. To trying different ROMs, nothing has helped so far.
Buddy1969 Well-known member Oct 25, 2012 266 0 0 Visit site Aug 7, 2014 #4 Maybe the headphone jack is stuck. You can try an insert a headphone, see if that works, then pull it out again and see if the earpiece works again. May be worth a try.
M martin bristow New member Sep 16, 2016 1 0 0 Visit site Sep 16, 2016 #5 Thankyou Buddy1969, inserting/removing the headphones on my Nexus 5x fixed the dead earpiece problem for me!
