Got a stock N5 on 4.4.4, that I do very little with - most of the Google apps are disabled, no social media, just use AquaMail for email & Textra for SMS. Data is always off unless I'm out & about when it's turned on as needed. Wifi is on.
During the day, doing the odd text & email, battery consumption is about 10% per 3-4h - this is both at work where phone signal is ok, and home and where signal is almost non existent.
Then bizarrely most nights just after I've gone to bed, battery use will then increase noticeably all night - often nearly double what it was. It's not a burst, it's a permanent step change to a new consumption rate.
Anyone else seen anything like this??
