Nexus 7: Severe battery drain while device is asleep
zackmack7
121
Hello all,
This past week my Nexus 7 2013 has been experiencing some really bad battery drain. I first noticed it Monday morning. I went to sleep with 90% and woke up with 39%. This is with turning wi-fi and everything off. I thought it was just an anomaly, but then twice more over the past few days. Here is the most recent screenshot showing battery status:
Instead of normally lasting upward of 2.5 day, it is barely getting past 1 now.
As you can see, it shows shows Wi-fi was on throughout the day/night, even though I am 100% sure I turned it off. Even if it was on, it shouldn't lose 50% just sitting there.
It's completely stock, hasn't been rooted. I don't drop it or anything. I even tried clearing the partition cache, without any luck on fixing the issue. Any input on what to try would be great! Thanks
*I got the tablet back in August, so it's almost 7 months old (still under warranty at Best Buy??).
**UPDATE**
Here are the screenshots from last night/this morning. I let it charge completely before I went to bed. Wifi is turned off. Lost 33% overnight. Not as drastic, but still very bad. The wifi icon is active in the notification bar because I turned it on this morning to upload the screenshots.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Re: Severe battery drain while device is asleep
Could you post a screenshot of the fill battery stats? Not just the graph.
7 months is too long to still be under warranty. Don't think insurance would cover this either
Sent from my Galaxy S4 running SlimKat 4.4.2
zackmack7
121
Figures. And I'll have to take a screenshot of that tomorrow morning, since I'm sure it will happen again tonight. I'll post both again tomorrow
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Not sure if this matters, but go to Settings>Wireless & Networks>Wi-Fi, then tap the menu button and Advanced, then make sure "Scanning always available" is unchecked.
I have seen this kind of behavior from time to time, usually on my 2012 N7. A reboot usually fixes it, but it can be hard to pinpoint what exactly is causing the drain.
Jon_Doh
400
6
I have the same problem with mine. Every app than can be Greenified is. Auto updates and syncing are turned off as is wifi. Screen brightness is almost to zero. Location is set to lowest settings, Google + is disabled. Yet, while it is turned off and in Airplane mode the battery drains like a sieve. It's not so bad when it is on and I'm using it. Looking at the battery usage the biggest user is the screen and Android OS and Idle. It makes absolutely no sense. I ran GSam for awhile to check for wakelocks and there were none.
I got great battery life until I updated to Kit Kat and on the same day put the tablet in a MoKo magnet case. I've wondered whether one or both of those things are causing battery drain.
zackmack7
121
I do have this enabled, but I have always have had it on. Some of my apps don't work well without it.
zackmack7
121
Updated the original post to show the more detailed and recent screenshots
zackmack7
121
How long have you been dealing with it? and how bad is the drain you are seeing?
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Tablet idle shouldn't be using that much battery. Download an app called GSAM battery monitor. It should tell you what's causing the battery to drain
gerryp123
133
Been there - done that!
After excessive battery drain I made sure to disable apps that were the source of multiple wake-locks (esp weather app, Google+. Google Currents, etc). Set everything to manual synch, esp for mail; reduced Notifications to only those that were essential. Also, screen "off" when not needed (podcasts, music) and esp during sleep.
All seems much better now. Only 2% battery drain overnight.
Jon_Doh
400
6
For a couple of weeks now. When turned sleeping it will drain 2-4% overnight, which isn't too bad, but as soon as I turn it on within a half minute it will dump 8%. Which means I've lost 10-12% since I last used it. To me this is excessive since everything is Greenified, Google + and Currents disabled, wifi scanning off, in airplane mode, etc. If I do anything besides read a book on it, then it drops in chunks of 4% every 10 minutes.
Buffster5505
23
My N7 2013 never uses more than 4% overnight ( 8 hrs ) ... but the other night it used more than 20% for that same period ....
Only thing I could attribute it to was that I had switched to Next Browser as my default browser and it had stayed opened in recent apps .... so for some reason it never Deep Sleeped.
Removed it from recent apps and my N7 returned to normal behavior ... So I ditched Next Browser and returned to Chrome.
B
zackmack7
121
Been a few weeks, and a few power cycles later, everything seems back to normal. Looks like I'm back to my normal 2.5 to 3 days of battery life.
Installed GSam like I was advised, and it really only showed the Kernel(Android OS) and Android System using most of the battery. In the meantime I disabled "Always Scanning" in the Wi-fi settings.
Thanks everyone for your input.
Sean bell
Hi. Since installing the last upgrade, I have had severe battery drain to the point where there is no life at all left on my tablet. It's been on charge for 3 days now with no signs of life until 3.30am this morning when i finally got it to turn on. 8% battery life and charging it said so left it alone. Got up this morning, nada so can't implement any of the advice on this forum. Am seriously considering dumping google and moving to kindle instead. We should'nt have to turn this or that off on a quality product that we've paid good money for.
jerrykur
1,217
16
Are you using the charger and cable that came with the device? A phone charger does not output enough current. You need a charger that is rated for 5 volts at 1.2 or greater Amps.
Once you do get it running, go to the power screen and figure out what is consuming your battery. You might have a poor wifi connection, or live somewhere where there are multiple wifi connections and the "Always Scanning" setting is turned on so the unit is constantly looking for a better connection. You may also have a bad app that is constantly running. But the key is to get to the battery/power screen and figure out what is using power.
Best of luck.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Welcome to Android Central! jerrykur's question is a good one--are you using the appropriate charger? And if so, have you tried any others, just in case your original charger coincidentally failed?
Also, do you have the 2013 N7 or the 2012?
preppystud
461
there are several battery apps in the play store. i use "du battery saver"
at night time, i close all apps, then use its "optimize" app, put it on airport mode, after a night, batter power usually go down by 3% only.
ebuyer abhinav
I was facing similar issue with my nexus 7 tab.
I was able to fix it by doing following changes:
1. Uninstalled updates of google play services
Now it is running on google olay services 4.3.23
2. Disabled auto-sync data
3. Disabled location
4. Disabled app: google search
Now I am getting very good standby time in my tab.
Hello all,
**UPDATE**
Jon_Doh
400
6
Recently my N7 started dumping 30 + % overnight while sleeping. This is after I turned off all syncing, keeping wifi always off, turn off Google voice commands and Greenified all apps. Nothing helped. So I disabled all Google services including Play, Framework, etc. Still didn't make a difference. When I would check battery usage it would say "Tablet Idle" was eating up my battery. Did a complete factory reset and wiped the system cache and the battery went back to its normal of only dropping 6% in 24 hrs of standby. Then once the battery got down to around 80% it dumped 33% overnight and the next night 20%. Something is definitely screwed up the the Nexus 7. I've tried every fix discussed on the forums and nothing helps. At this point, I'm done with the N7 and in the market for a new tablet.
