have nexus 7 2013 running 6.0.1, not impressed by battery life, when I check the battery settings it says 40% of battery life been used by wifi. I have have wifi notifications off and wifi set to never in sleep mode. Any ideas?
I am experiencing the exact same problem with an identical unit and 6.0.1. I don't remember this being a problem before the 6.0.1 update. I don't use the tab a lot, but if I leave the wifi on, even though I have it set to turn off when asleep, it will drain the battery at an amazing rate. I counter the problem by just turning wifi off (if I remember) when I am done using the device. I've tried many things to fix the problem wit no success. Any suggestions would be appreciated!
