- 11-25-2012, 10:42 PM
Thread Author #1
Nexus 7 problem; Won't charge, and when it does, screen goes dead and pixels fly across the screen.
Basically, my Nexus died while I was watching the Walking Dead, and I reserved to charge it when it was over.
Well the episode ended, and I plugged my Nexus in, but rather than come up with the Google and N7 logo, I received a black screen with pixels running across it.
I've decided to send it in to ASUS, even if it will take about 2 weeks, but I just want to know what happened.
Also, while I am under warranty, I am afraid they will try to charge me for it saying I "damaged the device" because of something ridiculous, like using a different charger (which I did).
Any answers and help would be greatly appreciated.l - 11-26-2012, 12:09 AM #2
Re: Nexus 7 problem; Won't charge, and when it does, screen goes dead and pixels fly across the
If the battery is really dead it has issues powering on until you charge it for an hour or so. This happened to me. I ran the battery down and it died on me when I tried to turn it on it was all funky. Graphics were wonky and it would turn off almost immediately even though it was plugged in. It was trying to use more power then it was receiving from the charger. I had to leave it plugged in, in then off position for an hour before I could turn it on.
- 12-01-2012, 08:15 AM #3
Re: Nexus 7 problem; Won't charge, and when it does, screen goes dead and pixels fly across the scre
Ive got literally this EXACT problem. Freaked me out. It would sometimes load the google screen then boot animation then do the crazy pixel thing. Sometimes it would just do the crazy pixels. Sometimes the screen just lights up and then goes back off really fast. Hmmm. It got to the lockscreen once and showed 0% and immediately died. gonna leave it on the charger(and keep an eye on it) and see if it works. Ive had my N7 for a few months and this is new. Are you both on 4.2.1? im on A beta for Paranoid Android Rom idk if its 4.2 or 4.2.1 maybe its ANOTHER bug in 4.2+
- 12-01-2012, 12:48 PM #4
- 12-04-2012, 09:50 AM #5
- 12-04-2012, 09:10 PM #6
Re: Nexus 7 problem
This is happening to me as well. It's on a login reboot cycle
- 12-04-2012, 10:34 PM #7
Re: Nexus 7 problem
What I did to solve this was un/plug my charger multiple times, then I held all the side buttons at the same time. Eventually, it would boot successfully, plugged in. Something else that was weird was that I was receiving such limited charge from my charger, it said I was charging via USB. After rebooting, it said it was charging via AC. One question is: when did you get your device? I got mine on August fifth.
Sent from my Nexus 7 using Android Central Forums - 12-05-2012, 10:10 PM #8
- 12-06-2012, 01:45 AM #9
- 12-06-2012, 08:35 AM #10
- 12-09-2012, 04:04 AM #11
This just happened to me right now then I saw this thread and I wanted to share what I did.
- Assuming your unit can boot long enough to do this, press and hold all the buttons (I'm not sure on the exact button combo) to give the device a hard reset.
- Keep holding the buttons till it reboots to the bootloader.
- Cycle through the menu selections and choose to power off the device.
- Unplug then re-plug the charger.
- You should now see the battery-charging icon. It shouldn't boot up on its own anymore. Just let it sit and charge to full capacity.Thanked by 13:+ Show/Hide list of the thanked
- 12-09-2012, 06:16 AM #12
- 12-09-2012, 06:15 PM #13
- 12-12-2012, 06:36 PM #14
Samsung Captivate - RIP 10-6-2011Currently: Samsung Galaxy S2 i777 - Rooted, Sim Unlocked and soon to be debloated
- 12-15-2012, 09:37 AM #15
Re: Nexus 7 problem
Signed up on the forums to come say this:
You don't need to press all three buttons (Power/vol-up/vol-down), just Power then vol-down to get in to the bootloader. Source: I just did it.
By the way, love the advice, I'd been frustrated and ready to eat the 200 dollars and never get another tablet. I had this very problem(not charging after battery died).
Thanks for the advice!Thanked by 2: - 12-19-2012, 02:44 PM #16
- 12-22-2012, 09:29 AM #17
I left my Nexus 7 on overnight while listening to the radio and in the morning it was totally discharged. I plugged it in... and nothing was happening. I left it for a while and again, nothing. I even plugged it to my PC, same story. I did a quick Google search and found EdsonDJ's post. Just followed the instructions... and WOW, it's charging now! Well, I'd like to thank you so much-I'm leaving for Christmas and I'm taking my Nexus 7 with me, so otherwise I would not have been able to bring it along... Well, put it this way: EdsonDJ has saved my Christmas--thanks!!!
- 12-23-2012, 10:29 PM #18
Is this a software bug or a hardware? will Google address this problem?
- 12-24-2012, 06:22 PM #19
AAAAHHH!!!! This just happened to me with my Nexus 7 32GB. Pixels flying across the screen and everything. Also there was a very worrisome buzzing/static sound coming from the tablet. Then it shut itself off and now I can't turn it on again. I can't even do that trick that EdsonDJ suggested because it won't power on at all even for an instant. Am I screwed? I bought it from BestBuy and their return policy is only 14 days. This damn thing isn't even 2 months old yet.
- 12-27-2012, 07:25 AM #20
Re: Nexus 7 dead and pixels fly across the screen.
I can't thank you enough edsondj. It just happened to me, it would power on for a split second. I had to reboot like 10 times before I got it to go to the loader menu. and I almost threw it against a wall. I finally got there and its charging.
God that's a terrible over sight on their part.
sent from my crappy thunderbolt... - 12-27-2012, 07:45 PM #21
I have discovered the infamous black static screen issue. You must open up the back cover of the nexus and make sure the battery connection is not loose. My nexus was 3 days old when it acted up so I opened it up and found the battery connection was never snapped in place. I hope this helps out.
Thanked by 2: - 12-29-2012, 04:01 PM #22
I have tried all the suggestions posted here and my N7 still will not respond, other then throwing it out after calling ASUS any other suggestions...Went it cycled off it was at 70% charge, could the battery be drained still.
- 12-29-2012, 09:09 PM #23
The reason why it won't charge is because......well there is many reasons...a different charger,to much usage, taking on and off and on the charger. Hope that helped
Tip* if you need to restart it you hold the power button for 20 seconds and it will turn on!! - 01-02-2013, 01:16 AM #24
This worked for me.
Peel off back cover. Push battery as explained previously to the opposite side of buttons.
Remove power and then replug. Replace cover.
Finally got the battery charging icon to show. I assume this is a good thing as I was not getting any indication before.
I may need to take cover off again and put a piece of paper in to make sure battery stays in contact with sensors if this happens again. - 01-02-2013, 10:07 PM #25
I had this problem 2 days ago. It would not charge at all, and every now and then it would chime when it would boot to the lock screen and then just shut down again. I got the "Dead Android" logo by holding down the buttons and forcing it to restart.
I did this a few times. Then one time I was holding it as it booted to the lock screen and I was able to pull down the wifi/battery menu and go to the battery properties. From there I was able to see the battery menu and then it shut down again, but this time it had the white battery icon on the screen indicating it was charging.
I just left it like that and in the morning it was charged and working.
I guess we aren't supposed to let it go completely dead or something. Not a good feature.
Nexus 7 won't charge
By mike.hadley99 in forum Google Nexus 7 TabletReplies: 16Last Post: 01-24-2013, 04:27 PM -
My Nexus 7 won't charge to 100%, just 97%
By NoahWL1 in forum Google Nexus 7 TabletReplies: 4Last Post: 11-21-2012, 05:25 PM -
Nexus goes in and out of charging even when not plugged in
By daygo619 in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 1Last Post: 03-13-2012, 05:11 PM -
Battery problems, won't charge. Looking for advice
By jmusso in forum AT&T CaptivateReplies: 1Last Post: 11-18-2010, 09:31 AM -
Does the EVO charge when it is turned off and plugged in?
By Schmid7y in forum HTC EVO 4GReplies: 8Last Post: 06-04-2010, 01:42 PM
Reply
