AnonymousUser
For the iPhone 4S, you can get MMS working by putting in a T-Mobile SIM (doesn't have to be active) then going into the internet settings and adding the ST MMS APN, then swapping SIMs again and saving it. The particular APN editing menu doesn't show up when you have an AT&T or ST SIM in it, but it does show up with a T-Mo SIM in it.
Theres plenty of info/guides out there on this method. No Jailbreak is required on the 4S (but is on the 4 and 3GS), because you can use this method.
Thank you for your reply in response to my dilemma.
I started by putting in my AT&T micro SIM into the iPhone 4S, as using the T-Mobile SIM was giving me an activation error & demanded I use an authorized carrier SIM. Once, I ejected it, I could access the home screen & Settings icon. With the T-Mobile Micro SIM inserted, I clicked on Settings, & once I click on Network to get to the APN, the screen goes back to the Activation screen again. I'm baffled.
Any ideas?
Man, I wish I could talk her back into Android again!
