Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By Vysse
  • 1 Post By mtdewed
    Default Lost my dialer
    I have an Evo 4g Lte, that I only use as a wifi device. Cellular isn't activated on it. Anyway ... I removed the Dialer from the homepage, thinking I could always replace it from the apps or whatever. The problem is ... I used the dialer to turn off the cell radio, by dialng *#*#4636#*#* ... But after actually powering down the device. I turned it back on and the cell radio is back on. I expected that part. But now I don't have access to the dialer.
    The only thing I can think of at this point is a factory reset.
    Any ideas?
  2. #2
    Default
    Go to app drawer then find the app named phone.
    Sent from my EVO using Android Central Forums
    Default Re: Lost my dialer
    Thanks Vysse. I don't have one though.
  4. #4
    Default
    Quote Originally Posted by mtdewed View Post
    Are you rooted? If so your kind of sol for now.
    Edit: Actually if your rooted you should be able to permanently set it like that.
  5. #5
    try downloading quick shortcut maker
    I'm not rooted. I tried QuickShortcutMaker. It did make the shortcut, complete with the right icon. But when I tried it, all I got was an error message. Thanks for the suggestion though. I never heard of that one.
    Looks like I'll have to do a factory reset. I was hoping to get around it.
  7. #7
    I'll cross my fingers for ya.
  8. #8
    Default
    Screenshot the error
    svargas05 likes this.
  9. #9
    newboyx's Avatar
    Posts
    ROM
    Something Beta
    Default
    How did you remove it?
    Sent from my EVO using Tapatalk 2
    "Something inspirational" ~ Some smart dude
    Hit the "Thanks" button
  10. Thread Author  Thread Author    #10
    I removed it by holding and sliding the dialer up to (Remove) at the top of the screen. I thought that would just remove the shortcut. But I'm starting to think it actually deleted the dialer.
  11. #11
    newboyx's Avatar
    Posts
    ROM
    Something Beta
    Default
    Go into settings - apps - all apps
    And find all apps/processes with dialer or phone in the name and click on them to make sure that none of them are disabled.
  12. Thread Author  Thread Author    #12
    In Settings - Apps - All ... Both Phone and Dialer are enabled and running.
    I tried the quick shortcut maker, which found quite a few things to link to. But all of them either came up with that same error, or said ... Sorry, you can not launch this activity from this app.
  13. #13
    malikshuman's Avatar
    Posts
    ROM
    MeanRom
    Default
    Did you try going to the people app and clicking on the dialer from there?
  14. Thread Author  Thread Author    #14
    Quote Originally Posted by malikshuman View Post
    Thanks ! That worked ... I didn't know there was a dialer there. I tried some dialers from the market, but those didn't access the cell radio info.
  15. Thread Author  Thread Author    #15
    Turns out I had the People app disabled, which in turn disabled the phone. Cause now my Phone app is back. Also, I used QuickShortcutMaker to go straight to that info screen. Which saves a lot of dialing.
    Anyway, Thanks for your help everyone. I really appreciate it
    TonyLibations likes this.
