Need some help please. I am just rooting and I am floowing instructions and it says open Command Prompt. When I click on ADB it opens the prompt and then closes it. What am I doing wrong?
If you're in windows 7, view the folder in Windows Explorer then hold down the left shift key and right click on the tools folder, then select open command prompt here.
Or in other windows version go to start, run, type cmd and hit enter.
