I have a question this will froyo update fix the 30 fps cap on the evo? the nexus one doesnt have a cap neither does the aria why. this is so annoying
i think i read somewhere that they were getting 90fps on 2.2 with an evo
I could careless about the 30 FPS cap. I dont need more than 30 to play a game anyways. I can deal with 25.
We need the source code to fix this. Once we get that we can adjust the kernel or drivers to fix this.
While I think the level of bitching on this is over blown you will notice a hugh difference and htc should not have done such a sloppy coding job.
Forgive the conspiracy theory, but I wonder if HTC is delaying the release. The reason they would want to do that is because it is perhaps not fixable in the kernel. So they would want to sell as many EVOs as possible before the bad press gets worse. Plus they could get past the 30 day return window for the early adopters who would return it if they knew there was no hope of fixing it.
Ok enough negative waves. That's my glass is half empty Outlook for the day.
"Android framework engineer "Romain Guy" isn't quite sure where this problem is coming from. He wrote a response, saying that for the record the "target was, is and will be 60fps." Strangely the Nexus One, which has official Froyo support already, also seems to be having the issue. It at least starts out during the Froyo running load animation at 60 fps (which allows it to appear smooth), but its framerate subsequently drops to 30 fps upon reaching the home screen."
DailyTech - EVO, Nexus One Framerates Capped at 30 FPS; It's Unclear Why
Anything OVER 30 FPS is overkill. Sure it MIGHT look a bit smoother but games are meant to be played at 30 FPS. I just like seeing higher numbers.
I don't disagree that I'll notice a difference.... I am tired of every evo forum I visit seeing new threads started daily about the same complaint. I am ok with what I have 60+ fps would be awesome but what I have works and does a decent job at it.
