A little list of things to do, check and or disable;
1. Use spare parts and find out whats killing your battery ie partial wake usage, cpu etc.
2. Turn your window animations from all to only some animations
3. Turn off automatic display and keep it around 20-30%
4. I have auto sync off on all my appz (E-mail, Gmail, Facebook etc.). I update my E-mail and such manually.
5. Turn off data when not using it. I find data accounts for around 15-25% of juice used and thats just when on idle.
6. Only use widgets on the homescreen if you really have to (Running widgets use a lot of power over time)
7. Use Android Hackers tool from the market and it will break down how long your cpu was in a certain state. ie my cpu spent 65% at 245mhz and 28% at 806mhz.
8. Keep off 4G, Bluetooth, wirless networks for location and GPS if not using it (GPS uses less power than wireless networks and is more accurate anyway) I assigned Quick Settings to open when I hold down the search button. That makes it easy to enable/disable any of these setting within seconds.
9. Turn off google talk and make sure it doesnt sign in automatically (most people dont realise this)
10. Turn screen timeout to 15 or 30 seconds (if longer your phone can keep the display on accidentally while in your pocket if a button is pressed, wasting power)
11. Dont use a task killer unless its to kill an app you know drains your battery and therefore must be closed to save juice
12. Check your apps. Some apps keep using cpu etc because they were not programed correctly. (some appz I've found to drain my battery are; Yahoo Mail, Craigslist, AndTorrent and the market if a download is hung up. There are a few others I cant remember off the top of my head) If your phone is getting hot for no apparent reason this may be the cause.
13. Calibrate your battery by bump charging (charge your phone till its full while on, turn it off and charge till its full again. Then bump charge it around 5-7 times) Wipe battery stats if applicable. If you have a car charger, plug your phone in on the way to work to account for the little bit of drain that occurs once the phone is fully charged yet still on the charger.
