Power Saver Mode Trigger? Just like Extreme Power Saver Mode using Tasker
Bart Pascoal
3
**Update, I found a solution using Tasker see follow-up comment**
As you know the "Extreme Power Saver Mode" allows you so set a threshold trigger of 5%, 10%, or 20%
I can't figure out how to do something similar for the normal (not "extreme") "Power Saver Mode". What I'd really like to do is set the phone to enable "Power Saver Mode" at around 60% battery.
I'm quite adept at Tasker but I can't seem to find any API to toggle "Power Saver Mode" on/off
I welcome your ideas, thanks!
Bart Pascoal
3
Re: Power Saver Mode Trigger? Just like Extreme Power Saver Mode?
There wasn't anything on Google but after much work in Tasker I seem to have found a solution.
Prerequisite A
Root
Prerequisite B
Tasker
Prerequisite C
Tasker Secure Settings
Step 1
Create a batter level profile. I created one for 75-100%
Step 2
Add Action select Plugins (this is where you need the secure settings plugin)
Step 3
Select "HTC Models" from Custom ROM Actions
Step 4
Power Save Mode Disable (For my profile I want it disabled at 75-100%)
Alternatively you could just import the profile I created:
<TaskerData sr="" dvi="1" tv="4.3u3m">
<Profile sr="prof15" ve="2">
<cdate>1398369273989</cdate>
<clp>true</clp>
<edate>1398464948788</edate>
<id>15</id>
<mid0>16</mid0>
<nme>Power Saver</nme>
<State sr="con0" ve="2">
<code>140</code>
<Int sr="arg0" val="75"/>
<Int sr="arg1" val="100"/>
</State>
</Profile>
<Task sr="task16">
<cdate>1398369288011</cdate>
<edate>1398464889853</edate>
<id>16</id>
<nme>Power Saver On</nme>
<Action sr="act0" ve="5">
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra.BLURB>Power Saver Mode - Disabled</com.intangibleobject.securesettings.plugin.extra.BLURB>
<com.intangibleobject.securesettings.plugin.extra.BLURB-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.BLURB-type>
<com.intangibleobject.securesettings.plugin.extra.ENABLED>false</com.intangibleobject.securesettings.plugin.extra.ENABLED>
<com.intangibleobject.securesettings.plugin.extra.ENABLED-type>java.lang.Boolean</com.intangibleobject.securesettings.plugin.extra.ENABLED-type>
<com.intangibleobject.securesettings.plugin.extra.EXTRA_SPINNER_OPTION>user_powersaver_enable</com.intangibleobject.securesettings.plugin.extra.EXTRA_SPINNER_OPTION>
<com.intangibleobject.securesettings.plugin.extra.EXTRA_SPINNER_OPTION-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.EXTRA_SPINNER_OPTION-type>
<com.intangibleobject.securesettings.plugin.extra.SETTING>htc_modes</com.intangibleobject.securesettings.plugin.extra.SETTING>
<com.intangibleobject.securesettings.plugin.extra.SETTING-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.SETTING-type>
<com.twofortyfouram.locale.intent.extra.BLURB>Power Saver Mode - Disabled</com.twofortyfouram.locale.intent.extra.BLURB>
<com.twofortyfouram.locale.intent.extra.BLURB-type>java.lang.String</com.twofortyfouram.locale.intent.extra.BLURB-type>
<net.dinglisch.android.tasker.subbundled>true</net.dinglisch.android.tasker.subbundled>
<net.dinglisch.android.tasker.subbundled-type>java.lang.Boolean</net.dinglisch.android.tasker.subbundled-type>
</Vals>
</Bundle>
<Str sr="arg1" ve="3">com.intangibleobject.securesettings.plugin</Str>
<Str sr="arg2" ve="3">Secure Settings</Str>
<Int sr="arg3" val="0"/>
</Action>
</Task>
</TaskerData>
Bart Pascoal
3
Forgot to say Part 2 is you need to set a lower Battery Profile 0-74% with Battery Saver On
So that's 2 profiles one for 0-74 and another for 75-100
There's probably a way to do them all in the same profile but this works.
<Profile sr="prof2" ve="2">
<cdate>1398467403264</cdate>
<clp>true</clp>
<edate>1398467532441</edate>
<id>2</id>
<mid0>4</mid0>
<nme>Power Saver ON</nme>
<code>140</code>
<Int sr="arg0" val="0"/>
<Int sr="arg1" val="74"/>
</State>
</Profile>
<Task sr="task4">
<cdate>1398467417327</cdate>
<edate>1398467438054</edate>
<id>4</id>
<nme>Power Saver 2</nme>
<code>11820</code>
<Bundle sr="arg0">
<Vals sr="val">
<com.intangibleobject.securesettings.plugin.extra.BLURB>Power Saver Mode - Enabled</com.intangibleobject.securesettings.plugin.extra.BLURB>
<com.intangibleobject.securesettings.plugin.extra.ENABLED>true</com.intangibleobject.securesettings.plugin.extra.ENABLED>
<com.twofortyfouram.locale.intent.extra.BLURB>Power Saver Mode - Enabled</com.twofortyfouram.locale.intent.extra.BLURB>
</Vals>
</Bundle>
</Action>
</Task>
</TaskerData>
Non
